Filter
Second filter
Third filter
Fourth filter
Shop
Showing 1–24 of 834 results
Sort by:
Dasduino COREPLUS (ATmega2560)
The soldered version of the ATmega2560 microcontroller board has arrived! It is designed for enthusiasts and professionals in the field of electronics and DIY projects. The heart of the board, the ATmega2560, is a powerful 8-bit microcontroller that offers enough processing power for demanding applications. The board comes with a large number of digital and analog inputs/outputs, allowing users to connect various sensors and actuators. The ATmega2560 contains a significant amount of Flash memory, SRAM, and EEPROM, which is sufficient for complex applications and data storage. The USB interface allows for easy programming and communication with a computer. It enables communication with various peripheral devices and modules using the easyC system for simple connectivity. The board is compatible with popular development environments, such as Arduino IDE, which facilitates the development and implementation of projects.
This board is ideal for creating complex and versatile electronic projects, such as automatic systems, smart devices, robotics, and many others.
Dasduino COREPLUS (ATmega2560) options:
Dasduino COREPLUS comes in 3 versions depending on the method of connection to the pins:
– without headers
– with male headers
– with female headers
Nokia 5110 monochrome LCD breakout
The Nokia 5110 breakout is yet another in our series of modules that bring the classic Nokia 5110 LCD display to life in your modern projects. With its core being the TXB0104QPWRQ1 for efficient voltage-level conversion, this board bridges the gap between your microcontroller and the display, regardless of their voltage differences.
Whether you are an experienced engineer or just starting out, this breakout board is designed to inspire and enable your creativity. Its blend of advanced technology and user-friendly features makes integrating the Nokia 5110 display into your projects not just possible, but enjoyable. Dive into your next adventure with this board and let your imagination light up pixel by pixel!
ULX3S 12F FPGA board
The ULX3S is a fully open source, compact, robust and affordable FPGA board equipped with a balanced spectrum of extra components and expansions.
The ULX3s offers a wide selection of useful features and interfaces that enable it to serve as a broad spectrum module for installation in complex devices.
Onboard peripherals such as SDRAM, USB, Digital video out, FM/ASK antenna, ADC and DAC can make it audio/video powerhouse for signal processing and synthesis, motor control or SDR cases. You can emulate arcade machines or retro computers like Minimig (Amiga) or modern systems like F32C (MIPS/RISCV). It has 56 GPIO pins, all routed as differential pairs and a PMOD compatible pinout, opening it to a wide range of expansion options. If you are just starting with FPGA, you can also use the ULX3S as powerful Arduino and program it using Arduino IDE in seconds.
ULX3S uses powerful Lattice Semiconductor ECP5 series FPGA chip supported by the latest open-source toolchains. This makes the ULX3S one of the most powerful and desirable platforms for FPGA enthusiasts available today. ULX3S comes equipped with onboard WiFi, display, buttons, LEDs and storage. Flash it using the WiFi connection (over-the-air update), or with one of the bitstreams stored on SD card and browsed by onboard OLED display and buttons. Due to its battery-backed RTC, it can power down completely and wake up only on certain events making it useful for low power applications.
It has been actively developed since 2016 and is the result of collaboration between Radiona.org / Zagreb Makerspace and FER – Faculty of Electrical Engineering and Computing – University of Zagreb, Croatia.
ULX3S is being actively used in Digital Logic class at the University of Zagreb Faculty of Electrical Engineering and Computing, Croatia.
ULX3S 85F FPGA board
125kHz RFID board
125kHz RFID board
RFID is a type of communication in which information is transmitted wirelessly (Wikipedia article). Today, it is becoming increasingly popular and can be found in numerous and various cards: driving licenses, access control to buildings, public transportation, etc.
RFID readers come in many forms and variants. This reader, from our production, enables easy connection to a microcontroller, thereby opening up possibilities for developing various projects based on RFID technology. The breakout comes in two versions, and depending on the version, it is programmed and ready for communication via pins on the board. It has a switch for changing the data transfer speed (baud rate) as well as a connector for connecting the antenna that comes with the breakout.
Accelerometer & Gyroscope & Magnetometer LSM9DS1TR 9-DOF breakout
Discover the magic of motion tracking with our all-in-one Accelerometer, Gyroscope & Magnetometer LSM9DS1TR Breakout! This mini but mighty module bundles together a 3D accelerometer, a 3D gyroscope, and a 3D magnetometer. It lets you monitor not only linear and rotational movements but also the magnetic field surrounding your projects. Despite its pocket-size, it offers high-accuracy measurements — ±16 g for the accelerometer, ±2000 dps for the gyroscope, and ±16 Gauss for the magnetometer.
It has an embedded temperature sensor, FIFO buffer for data management, and interrupt features to signal your microcontroller when data is ready or when a certain event occurs. Plus, with I2C interface, it can easily connect with a variety of microcontrollers.
Our LSM9DS1TR breakout merges high-end capabilities with a user-friendly approach. It operates within a supply voltage range of 2.4V to 3.6V, making it compatible with both 3.3V and 5V systems. Its low-power and power-down modes optimize performance without draining too much energy.
This breakout board comes with 2 easyC connectors which will simplify connection with microcontrollers. By using the easyC module connection system, forget about incorrectly connected or, in the worst case, damaged modules.
Accelerometer & Gyroscope LSM6DS3 6-DOF breakout
Embrace the fascinating world of motion tracking with our Accelerometer & Gyroscope LSM6DS3 Breakout! This handy little board integrates a 3D accelerometer and a 3D gyroscope, allowing you to monitor both linear acceleration and rotational motion in your projects. Despite its compact form, it packs a punch with high-resolution measurements of up to ±16 g and ±2000 dps respectively. Whether you’re building a gesture-controlled robot, a fitness tracker, or a drone, our LSM6DS3 breakout is here to ensure precision and reliability in every motion tracking task.
But it’s not just about tracking movement. Our LSM6DS3 breakout comes with an array of impressive features to add extra layers of sophistication to your projects. It features an embedded temperature sensor, providing crucial temperature data in environments where accurate motion tracking is a must. Additionally, it boasts a FIFO (First In, First Out) buffer that allows you to store and manage data efficiently, offering you greater control over your motion tracking applications. The board uses I2C interface, providing compatibility with a multitude of microcontrollers.
Our LSM6DS3 breakout is a seamless blend of high performance and user-centric design. Operating on a supply voltage range of 2.5V to 3.6V, it is compatible with both 3.3V and 5V systems. Its low-power operating modes ensure optimal performance without significant energy consumption. Start your journey towards motion mastery with our Accelerometer & Gyroscope LSM6DS3 Breakout and add that unique engineering touch to your projects!
Accelerometer & Gyroscope LSM6DSO 6-DOF breakout
Step into the world of motion sensing with our nifty Accelerometer & Gyroscope LSM6DSO breakout! Small but mighty, this breakout board combines a 3D accelerometer and a 3D gyroscope on one tiny platform, letting you track both static and dynamic motions of your projects with ease. Its compact size doesn’t mean a compromise on performance – in fact, it offers high-resolution measurements of up to ±16 g and ±2000 dps respectively. So whether you’re building a drone, a VR game, or an IoT gadget, our LSM6DSO breakout will be your perfect companion for precise and efficient motion tracking.
Our LSM6DSO breakout is all about combining high-performance capabilities with user-friendly design. It operates on a supply voltage range of 1.71V to 3.6V, making it compatible with both 3.3V and 5V systems. Its power-saving features ensure that your projects keep running smoothly without draining too much energy. So, why wait? Add a dash of engineering magic to your projects with our Accelerometer & Gyroscope LSM6DSO breakout! With I2C interface, it’s a breeze to connect with various microcontrollers.
Out of stock Accelerometer & Gyroscope LSM6DSO32 6-DOF breakout
The LSM6DSO32 sensor breakout is a compact and versatile sensor module designed to provide precise motion sensing capabilities for various applications. It is based on the LSM6DSO32, a high-performance 6-axis Inertial Measurement Unit (IMU) manufactured by STMicroelectronics.
The breakout board features a tiny yet powerful chip that combines a 3-axis accelerometer and a 3-axis gyroscope, allowing it to measure linear acceleration and angular rate in three dimensions. This makes it an ideal choice for projects that require motion tracking, orientation detection, gesture recognition, and activity monitoring.
One of the key advantages of the LSM6DSO32 sensor breakout is its low power consumption, making it suitable for battery-powered applications, such as wearables, IoT devices, and remote sensing systems. Additionally, the breakout board offers flexibility and ease of use with its I2C and SPI communication interfaces, allowing seamless integration with a wide range of microcontrollers and development platforms.
Buzzer
Buzzer
A buzzer is a small speaker (actually a piezo). We all know what a speaker does, so no further explanation is needed. Here, we are talking about a passive buzzer which requires an AC signal to produce sound. It’s like an electromagnetic speaker, where a variable input signal produces sound, instead of automatically producing a tone.
DC connector breakout
Simple breakout that allows access to standard 2.4 mm pins of a DC connector.
GNSS GPS L86-M33 breakout with easyC
Global Navigation Satellite Signal Systems (GNSS), or as we all like to call it “GPS”, enable precise location determination on Earth. Thanks to this module, you can use GNSS for your project and use the device for asset tracking or create a wearable device. The module is small, energy-efficient, high-performing, and easy to use thanks to the built-in antenna.
L86-M33 is a GNSS receiver, which means it can receive signals from GPS, GLONASS, and Galileo constellations. Equipped with EASY (Embedded Assist System for self-generated orbit prediction) and AlwaysLocate technologies, L86-M33 ensures fast and accurate positioning even in challenging environments. Its advanced internal logger LOCUS allows you to store your routes and location data.
Our breakout board, in addition to the previously mentioned L86-M33 module which has an integrated antenna, also has a connector for a CR1220 battery which is used as a backup for timekeeping and GPS data. The module can operate without the battery, but every time it will have to fetch data from satellites afresh (cold start). If the integrated antenna is insufficient, there is an IPX connector on the board for adding an external, stronger antenna. The antenna we suggest can be found here. To easily access the module pins, the pins are extended on the board for accessibility. There is also a switch on the board to change the I2C address.
Make your own Dasduino Solder Kit
If you’re looking for a simple way to start soldering or just want to make your own Dasduino, this soldering set is a great opportunity. “Make your own Dasduino CORE” is an educational set for learning the skill of soldering, with which you end up with a functional microcontroller board. As with the other SMD versions of the Dasduino CORE boards we offer, the possibilities are endless.
It is based on the ATmega328P microcontroller, and all SMD components are already soldered on the board. The set also includes a THT socket for the microcontroller, which simplifies the replacement of the microcontroller should it ever become necessary.
The set consists of:
  • PCB
  • 7 capacitors of 100nF
  • 4 capacitors of 2.2uF
  • 2 capacitors of 22pF
  • 5 resistors of 2.2kOhm
  • 5 resistors of 10kOhm
  • 3 resistors of 1kOhm
  • 1 resistor of 100kOhm
  • 1 resistor of 100Ohm
  • 1 JST battery connector
  • 1 purple LED
  • 1 white LED
  • 1 blue LED
  • 1 red LED
  • 1 orange LED
  • 1 socket for ATmega328P
  • 1 ATmega328P microcontroller
PIR Movement sensor board with easyC
A PIR (passive infrared) motion sensor is a device that detects physical movement within its field of vision by sensing changes in infrared radiation. This sensor works on the principle of detecting thermal thermal signals emitted by objects, mostly warm-blooded creatures like humans. The “passive” in the name refers to the fact that the sensor itself does not emit or radiate any energy for detection.
When it detects motion, the sensor sends a digital signal to the microcontroller. The angle that the sensor “sees” is 100 degrees and reaches up to 5 meters. It is often used in a variety of applications, including home security systems, automatic lighting, and energy management, among others.
Our breakout board simplifies the use of the PIR sensor by using easyC technology, making it easily connectable with microcontrollers or other circuits. It accepts input from the PIR sensor and translates it into signals that your microcontroller can interpret. In addition to the aforementioned PIR sensor, the board also contains a small ATTiny404 microcontroller, as well as a switch for selecting the I2C address. This breakout board comes with 2 easyC connectors for easy integration into the easyC system. If you do not wish to use easyC, the module can also be used via standard headers.
Out of stock Rotary encoder board with easyC
Unleash the potential of digital control with our Rotary Encoder breakout board. Compact and powerful, this module makes working with rotary encoders easy. Rotary encoders are versatile input devices that convert angular position or button movement into digital signals. With the ability to detect direction and distance of rotation, they are perfect for controlling a variety of equipment such as volume knobs on audio devices, motors in robotics, or navigation controls in user interfaces.
Our breakout board simplifies the use of rotary encoders by utilizing easyC technology, making it easily connectable with microcontrollers or other circuits. It accepts input from a rotary encoder and translates it into signals that your microcontroller can interpret. In addition to the aforementioned rotary encoder module, the board also features a small ATTiny404 microcontroller, as well as a switch for selecting the I2C address. This breakout board comes with 2 easyC connectors for easy plug-and-play into the easyC system. If you don’t want to use easyC, the module can also be used via standard headers.
Soldered Inkplate 2
Soldered Inkplate 2
The Inkplate 2 is an Arduino-compatible board that features a 2.13″ three-color e-paper display. It is a plug-and-play device, programmable via USB port, and controlled by an ESP32 microcontroller. Moreover, it connects to the internet via WiFi or Bluetooth. Since it uses only 8uA in low-power mode, it can last for months on a single Li-ion battery charge. It’s simple enough to be used by beginners, but it also offers plenty of features and a user-friendly platform for advanced users. Inkplate 2 has it all, packed on a small-factor board.
If you’re like us, when you first saw an e-book reader, you thought “If only I could use a screen like this in my project”. Thanks to the exceptional sharpness and contrast, the ability to display in sunlight and truly unprecedented efficiency in terms of energy (it consumes energy only when changing the content on the screen), electronic paper is the ideal choice for many applications. Inkplate 2, continuing the tradition of the now well-known Inkplate series, offers a variation of e-paper accessible to hobbyists and everyone else in a way that we have created a plug-and-play hardware that is really easy to use, and is compatible with Arduino and micropython.
Inkplate 2 options:
With e-paper display & enclosure: This version offers a sturdy and sleek enclosure for your device, made with precision from a 3D printer. It’s perfect for those who want an extra layer of protection without any added features.
With e-paper display, enclosure, and battery: Upgrade to this version if you’re looking for both protection and mobility. This option includes a 3D-printed enclosure as well as an integrated battery, ensuring your device stays powered even on the go.
Without e-paper display: For those who prefer a simpler or alternative display solution, this version does not include the e-paper display. It’s ideal for users who have their own display solutions or prefer to use the device without a visual interface.
Choose the one that best fits your needs and enhance your experience!
Soldered Inkplate 5
Soldered Inkplate 5
Introducing the Inkplate 5, a versatile Arduino & Micropython compatible board that features a recycled 5.2″ E-Ink (e-paper) display with rapid refresh times of only 0.19 seconds. This fully open-source, plug-and-play device, powered by an ESP32 microcontroller, is designed to connect effortlessly to the internet via WiFi or to other devices through Bluetooth.
Its energy-efficient design allows for ultra-low power consumption, making it capable of running for months on a single Li-ion battery charge. The Inkplate 5 is not just about power and connectivity; it’s also about convenience. The onboard microSD slot and a Real-Time Clock ensure unlimited data capabilities and precise timekeeping. The device even boasts numerous GPIO pins, allowing for easy expansion of your projects with virtually any peripheral.
Inkplate 5’s e-paper panel display is a visual delight. It provides beautiful, crisp image under all conditions, including direct sunlight, that’s always-on. Its screen resolution is 960 x 540 pixels, in monochrome, with black, white and 6 shades of grey support. The most interesting bit? The E-Ink screen does not require any power in between screen updates.
Inkplate 5 does a full refresh as quick as 1.02s for full refresh and 0.19s for partial refresh. That’s 5fps, if you wish.
Our device is a fantastic entry point for those wanting to experiment with E-Ink technology, all neatly packed into a compact board.
Inkplate 5 options:
Soldered Inkplate 6
Soldered Inkplate 6
If you’re like us, the first time you saw an e-reader, you thought to yourself, “I could do something with that.” Thanks to clean lines, high contrast, daylight readability, and the remarkable level of energy efficiency that comes from drawing power only when changing the contents of the screen, e-paper is uniquely suited to many applications. With Inkplate 6, our goal is to make e-paper accessible to hobbyists and DIY product designers by offering a plug-and-play hardware platform that is super-easy to use and compatible with Arduino.
To name a few features, Inkplate 6 has stunning 6 inch e-paper display with refresh rate of 1.26s, with partial update 264ms, greyscale mode and partial updates support. Powered by ESP32, you will have strong microcontroller with WiFi and Bluetooth on your disposal. It’s super-low-power (22uA) so you can use it for days, weeks, or months out of a single battery charge. Using our Arduino library (100% compatible with Adafruit GFX), it’s 5 minute work to get the board running for you. The Micropython module is available as well.  It’s 100% open-source for both software and hardware. What is especially interesting is that Inkplate uses recycled screens taken from old e-book readers, which is very environmentally friendly, but you have to keep in mind that some screens may have small scratches because of this. All screens with large scratches and damages are not used at all.
Inkplate 6 options:
Out of stock Inkplate 6 - 6" e-paper board with enclosure
To name a few features, Inkplate 6 has stunning 6 inch e-paper display with refresh rate of 1.26s, with partial update 264ms, greyscale mode and partial updates support. Powered by ESP32, you will have strong microcontroller with WiFi and Bluetooth on your disposal. Using our Arduino library, it’s 5 minute work to get the board running for you. It’s 100% open-source for both software and hardware, so it’s OSHWA certified. What is especially interesting is that Inkplate uses recycled screens taken from old e-book readers, which is very environmentally friendly, but you have to keep in mind that some screens may have small scratches because of this. All screens with large scratches and damages are not used at all.
Soldered Inkplate 6PLUS with enclosure - e-paper display with touchscreen - USB only
If you’re like us, the first time you saw an e-reader, you thought to yourself, “I could do something with that.” Thanks to clean lines, high contrast, daylight readability, and the remarkable level of energy efficiency that comes from drawing power only when changing the contents of the screen, e-paper is uniquely suited to many applications. Following Inkplate 6 and 10 success, with Inkplate 6PLUS we continue to make e-paper accessible to hobbyists and DIY product designers by offering a plug-and-play hardware platform that is super-easy to use and compatible with Arduino. 6PLUS adds touchscreen and frontlighting, making it a perfect solution for interactive projects.
To name a few features, Inkplate 6PLUS has stunning 6.0 inch e-paper display with refresh rate of 1.27s, greyscale mode and partial updates support. Additionally, it had touchscreen with possibility to detect two simultaneous touches, as well as front lighting controllable in 64 steps. Powered by ESP32, you will have strong microcontroller with WiFi and Bluetooth on your disposal. There’s Real Time Clock (RTC), additional GPIO pins, and more. Using our Arduino library (100% compatible with Adafruit GFX), it’s 5 minute work to get the board running for you. The Micropython module is available as well.  It’s 100% open-source for both software and hardware. What is especially interesting is that Inkplate uses recycled screens taken from old e-book readers, which is very environmentally friendly, but you have to keep in mind that some screens may have small scratches because of this. All screens with large scratches and damages are not used at all.
Soldered Inkplate 6COLOR
If you’re like us, you thought: “If only I could use a screen like this in my project”, first time you saw an e-book reader. Thanks to the exceptional sharpness and contrast, the ability to display in sunlight and truly unprecedented efficiency in terms of energy (it consumes energy only when changing the content on the screen), electronic paper is the ideal choice for many applications. Inkplate 6COLOR, continuing the tradition of the now well-known Inkplate series, continues to offer variations of e-paper accessible to hobbyists and everyone else in a way that we have made plug-and-play hardware, really easy to use and compatible with Arduino and micropython. Inkplate 6COLOR brings a unique innovation – the ability to display colors on the screen.
If we want to list only a few features, Epaper Inkplate 6COLOR has a 5.85-inch folded e-paper that displays a total of 7 different colors (Black, White, Red, Yellow, Blue, Green, and Orange). Considering the built-in dithering capability, the results you can get on the screen are really impressive. Powered by ESP32, you will have strong microcontroller with WiFi and Bluetooth on your disposal. It’s super-low-power (18uA) so you can use it for days, weeks, or months out of a single battery charge. Using our Arduino library (100% compatible with Adafruit GFX), it’s 5 minute work to get the board running for you. The Micropython module is available as well.  It’s 100% open-source for both software and hardware. What is especially interesting is that Inkplate uses recycled screens taken from old e-book readers, which is very environmentally friendly, but you have to keep in mind that some screens may have small scratches because of this. All screens with large scratches and damages are not used at all.
Inkplate 6COLOR options:
items per page
