In this category, you can find all products from the offer that are on sale.
To claim an additional 30% discount, enter “SALE30” in the coupon field on the shopping cart page.
Showing 1–24 of 203 results
High-quality USB-C male to classic USB-A male cable 300cm long, with all communication and power lines.
JST (more precisely JST XH) connectors are today the most common connectors for rechargeable lithium batteries but are also used for many other applications where a fast, easy and convenient connection is required.
Connector JST (more specifically JST PH) is nowadays the most common connectors for rechargeable lithium batteries, but they are also used for many other applications where fast, easy and favorable connection is required.
JST (more specifically JST PH) connectors are nowadays the most common connectors for rechargeable lithium batteries, but they are also used for many other applications where fast, easy and favorable connection is required.
The XT60 connector is a popular choice for electronic projects that require a reliable, high-current connection. This connector features a bullet-style design and can handle currents of up to 60 amps.
The XT60 connector is made from high-temperature nylon and gold-plated contacts, providing a secure and low-resistance connection. It is easy to use and comes in a genderless design, allowing for easy polarity connections.
This connector is widely used in RC hobby applications, drones, and other electronic projects that require a safe and reliable connection. Its technical specifications and reliable performance make it a popular choice among hobbyists, engineers, and professionals alike.
If you need a high-current, low-resistance connector for your next electronic project, consider the XT60 connector for its durability and safety.
Standard M3 countersunk head screw.
Classic SMD LED inside 3528 package with 8 lm of luminous power.
NEMA17 is a smaller stepper motor with high precision. Often we find it in 3D printers and small CNC machines since it has sufficient power to move small items. You will also use it in the 3D printer, CNC, robot or for the accurate control of anything which turns or moves.
We recommend the A4988 stepper motor driver.
This driver for stepper motor enables control over a stepper motor that does not require more than 500mA of current and works at 5V-12V voltage. Except for the driver, it has built-in LED lights that indicate which phase of the motor is currently active. Connecting on Croduino/Arduino is simple, and control is directly through the library.
Stronger driver for stepper motor which has more options than the classical ULN2003. It comes in small packaging and you could easily control the size of its steps.
This TMC2208 module can be used to control stepper motors up to 2 A for 3D-Printing, Cameras, Scanners and other equipment.
We all know these little DC motors, especially if you’ve ever disassembled any toy. They are everywhere, and now at the Soldered.com.
DC motors can be inconvenient to use on low speed. With the help of mechanic and transfer using sprockets speed of this motor is slowed to a remarkably small speed. It is used for precise control over many mechanisms from robot wheels to precise mechanics.
• Voltage: 3V
• Axle diameter: 3mm
• Dimensions: 12mm x 10mm x 36mm
• Voltage: 3V
DC motors can be inconvenient to use on low speeds. With the help of mechanics and transfer using sprockets speed of this motor is slowed to a remarkably small speed. It is used for precise control over many mechanisms from robot wheels to precise mechanics.
• Voltage: 3V
A small power supply that provides 3A on 5V via micro-USB cable. You might recognize, this is a perfect power supply for the Raspberry Pi. It would also find its place in some other uses, such as powering up a micro-USB device or charging a device with a battery.
A classic small power supply with an output of 5V, 3A that will ideally power your project in which you use an Arduino / Dasduino or any other device. It has a standard female USB-C connector on the output. You can connect the cable from the board directly to this charger and use it as a constant power source. Furthermore, you can use it to charge your cell phone / tablet. Or for a third purpose …? Either way, it will serve you well!
This Raspberry Pi case is designed for the classic full-sized Raspberry Pi. With this case, your Raspberry Pi is safe from external sources and possible damage. It also provides easy access to all connections and GPIO pins.
It’s a good idea to pick up Raspberry Pi and a card for his operating system right from one place, so we started to offer microSD cards.
• microSD card
• Capacity: 32GB
This adapter makes it easy to connect easyC devices and sensors to the Raspberry Pi. It has 2 soldered easyC male connectors and a female header for Raspberry Pi, next to the header there are pins for connecting 5V and 3.3V and ground pins. It simply connects to the Raspberry Pi because its pinout matches the pinout of the Raspberry Pi.
The threaded insert is used to repair a damaged thread, for inserting into soft materials where it provides a permanent thread (eg. plastic).
A loadcell is a small device that is able to weigh the load that is on it. Depending on the load, it provides very small output voltages that needs to be amplified (e.g. using an op-amp or an ADC with a built-in op-amp) in order to be able to do useful things with it. It has two fixed and two variable resistors connected to the Wheatstone bridge.
It needs to be connected to the HX711 board so you can read the readings with the Croduino. For more details, see How to Use the Module Tutorial in the upper right corner.
