This product has been retired from our shop and is no longer for sale. This page is made available for those looking for datasheets and the simply curious.
Out of stock
Notify me when back in stock
This product is retired and we won’t sell it anymore. This page is for reference only.
Reflow oven is used to achieve a precisely controlled soldering cycle using solder paste. Thanks to the controller, this machine will follow the preset solder profile very precisely with minimal deviations, which will result in perfect solder joints. Regardless of the size of the board and the thermal mass on it, thanks to 2 IR heaters, this oven will solder everything properly. You can forget about cold solder joints, incorrect flux evaporation and board cleaning after the process. You can use the machine for the classic soldering process, i.e. prototyping, but also for “re-reflow” method if some joints are not correct.
Using the LCD screen and 4 buttons it is possible to choose between 7 preset soldering profiles. There are already all the standard profiles for leaded, lead-free and low-temp solder paste. If you need to adjust your soldering curve, you can also do this precisely, entering the temperature for each time point. The T962 oven is so popular that you will find tutorials all over the internet on how to further improve your oven, mechanical upgrades and firmware updates. In the production of e-radionica.com, this oven has been used for years for prototyping and works great.
• Manufacturer and model: Puhui T962
• Power: 800W
• Maximum board size: 180 x 235mm
• Cycle duration: 1 – 8min, programmable
• Temperature range: 0℃ – 280℃
• Input voltage: 230V
• Dimensions: 31 x 29 x 17 cm
• Weight: 6.2kg
Be the first one to leave a review for this product.
To provide the best experiences, we and our partners use technologies like cookies to store and/or access device information. Consenting to these technologies will allow us and our partners to process personal data such as browsing behavior or unique IDs on this site and show (non-) personalized ads. Not consenting or withdrawing consent, may adversely affect certain features and functions.
Click below to consent to the above or make granular choices. Your choices will be applied to this site only. You can change your settings at any time, including withdrawing your consent, by using the toggles on the Cookie Policy, or by clicking on the manage consent button at the bottom of the screen.
You must be logged in to post a review.
